Measurement Studio for VC++
Distortion Measurement for C
I am using a DAQ 6009 and I have two 3-axis accelerometers hooked up to ports ai0-ai5 in RSE mode. The acclerometers are ADXL335's and I made custom scales for their voltages to convert the voltages into accleration measurements (g). I am using Signal Express to analyze the signals, while building on the VC_TDMS_Cont_IntClk example C code in Visual C++. I can export the data points fine to an excel TDMS file. However, in Signal Express there is the Distortion option which gives you the Fundamental Frequency and the Power Spectrum. I wish to get this data through my C code. Is this possible? I do not see any API functions provided in the sample code that support this. Thank you in advance.
Best Regards,
Scott
(5,622 Views)
    So there is an example file that we have for distortion measurements.  If you go to CVI » Example Finder » Browse tab » Analyzing and Processing Signals » thd.cws
    Also there should be plenty of C code that you can search for on the internet.
http://zone.ni.com/reference/en-XX/help/370051P-01/cvi/libref/cviharmonicanalyzer/
Daniel
Applications Engineering
(5,614 Views)
