Measurement Studio for VC++
Dual Sine Graph
Hey, I was wondering how do you change the amplitude and the amount of cycles in a Dual Sine Graph. The Dual Sine Graph code is:
// Graph the dual sine graph
// Declare variables and constant
const int SIZE = 41;
double xData[SIZE];
double yData[SIZE];
double zData[SIZE][SIZE];
// Use a for loop to go through each array point
// and store in a number that results from the equation
for (int i = 0; i < 41; i++)
xData[i] = (i - 20.0)/20.0 * PI;
yData[i] = (i - 20.0)/20.0 * PI;
// Use two for loops to go through each matrix point of zData
// and store in the results from an equation
for (i = 0; i < 41; i++)
for (int j = 0; j < 41; j++)
zData[j][i] = sin(xData[i])*cos(yData[j]);
// Convert the native C++ double
arrays to NI data types for visualization.
CNiReal64Vector xVector(SIZE, xData);
CNiReal64Vector yVector(SIZE, yData);
CNiReal64Matrix zMatrix(SIZE, SIZE, *zData);
// Plot the data
m_c3DGraph.Plot3DSurface(xVector, yVector, zMatrix);
I am wondering in which part of the code can you change the amplitude and how do you change the amplitude. I am also wondering in which part of the graph can you change the period of the graph and the amount of cycles. Thanks.
(3,030 Views)
Take a look at the CNiMath::SineWave method. It has parameters that will let you specify phase, amplitude, frequency, and number of samples. Note, however, that the CNiMath methods work with CNiReal64Vector and not with C++ double array types.
- Elton
(3,030 Views)
