Measurement Studio for VC++
Equivalent command to ibonl(0,0)
When I call CNi4882Board::Reset(), I get ibonl(GPIB,1). Which command in CNi4882 will indirectly call ibonl(0,0) or ibonl(GPIB0, 0)?
(3,459 Views)
Reset is the only function that calls ibonl. ibonl is only used when resetting or disconnecting from a device. I can't think of anytime you would want to call it otherwise. Therefore, Reset is our only function that calls it (for a board or device), and it's taken care of for you when you discard the object in deconstruction.
Best Regards,
Chris Matthews
(3,459 Views)
