Measurement Studio for VC++
Equivalent function of DAQ_VScale in Daqmx
Hi
I would like to know the equivqlent function of DAQ_VScale of traditional Daq
in Daqmx.
My application is to measure DC volatge.
My DAQmxReadAnalogF64() function is acquiring but,
i am getting the data in the raw format.
In the Daqmx  series, how is the scaling or transform data to voltage
is taken care.
or
do i get the voltage directly from the DAQmxReadAnalogF64() function.
do let me know
regards
rags
(5,997 Views)
Hello Rags,
The value returned by your analog input (AI) function (such as AI_Read) is an array of integers that represents the analog to digital (A/D) conversion of your data. The DAQ_VScale and AI_VScale functions convert the integer values to an actual voltage reading (LabVIEW does the conversion automatically).
If you look at page B-8 of the NI-DAQ Function Reference Manual, you will see that the formula is listed there. What you could do is read the raw data using DAQmx and then just apply that formula to your readings. In DAQmx the scaling is automatically taken care of for you. Are you sure you are using the DAQmxReadAnalogF64 function and not the DAQmxReadAnalogScalarF64 function?
Best Regards,
Raajit L
Raajit L
(5,975 Views)
Hi Raajit L
Thank you for the reply.
i am using DAQmxReadAnalogF64 function , a slight change
and i am able to acquire the voltage now, as you  have told the functions returns the voltage
regards
rags
(5,972 Views)
