Measurement Studio for VC++
Error -200220 for DAQmxCreateAIVoltageChan
My code, which is:
TaskHandle h=0;
int32 b = DAQmxCreateTask("Task1",&h);
int32 a = DAQmxCreateAIVoltageChan(h , "Dev1" , "Voltage", DAQmx_Val_Cfg_Default, -10.0, 10.0, DAQmx_Val_Volts, NULL);
produces an error (The value of a is -200220.). I have the simulated NI USB-6251 as Dev1 running in NIMax. The reason that I know it is running properly is that when I use DAQmxGetSystemInfoAttribute, the name "Dev1" appears as one of the detected devices names.
But I don't understand why I still get the DAQmxErrorInvalidDeviceID error.
(b is 0 though!)
I would really appreciate if anyone could help me solve the issue.
Thanks.
(6,539 Views)
Hi NIMaxUser,
Do you have the same problem when you try to communicate with other simulated devices or just dev1?
Sinead B.
(6,307 Views)
Thanks, the problem was solved by adding the ai0 to the command.
(6,299 Views)
