Measurement Studio for VC++
Error on calling ChartXY from a thread
my program crashes (Unhandled exception) when I call ChartXY from a thread I start, and does what I expect when I call ChartXY from outside the thread.
I have a class with a member function
void
CGraphDlg::DisplayDataPoint(double x, double y, bool FirstDataPoint)
m_UpperGraph.ChartXY(x, y);
m_LowerGraph.ChartXY(x, y);
When I call this function from my View class
m_pGraphDlg->DisplayDataPoint(1, 2, 1);
everything works fine. When I start a thread and call this function
(pO
->m_pGraphDlg)->DisplayDataPoint(2, 3, 0);
I get an "Unhandled Exception".
When I trace into the DisplayDataPoint function to check the value of the pointer to the CNiGraph object m_UpperGraph, it's the same in both function calls.
Your help would be appreciated!
Best regrads,
Kurt
(3,838 Views)
You need to call CoInitialize(NULL) as the very first function in your new thread to initialize COM. Make sure you call CoUninitialize() before you exit the thread. One of the golden rules of Win32 programming is that you cannot access UI elements from a thread other than the one that created it. We added some additional functionality to the CNiGraph to be able to do this without too much extra code. Plus MFC initializes COM for you in the main thread and this graph is a COM component. But for any other thread that you create, you need to manually initialize COM for that thread by calling CoInitialize(). Otherwise you get crashes like the one you described.
I hope this helps
Message Edited by bilalD on 07-06-2005 10:14 AM
Bilal Durrani
NI
(3,835 Views)
thanks a lot for your answer. Now it works!! Probably I would have never found this bug without your help.
Kurt
(3,830 Views)
I have the same problem.but, Now it has been solved!!
Thank you very much.
Sincerely.
(3,354 Views)
