Measurement Studio for VC++
Escape Sequence
Is it possible to use an escape sequence for a button control so I can put text on 2 different lines of a button?  I've tried using a \n in the property pages and also using a \n with the SetOnText function.
For example:
Turn Off
Graph 2
Thanks in advance for any help!
Geoff.
(6,208 Views)
Geoff,
Which Measurement Studio control are you trying to do this for? The text are just captions on these buttons and since MFC doesn't let you use \n, you could always just place another caption.
Brandon Vasquez | Software Engineer | Integration Services | National Instruments
(6,198 Views)
