Measurement Studio for VC++
FiilTo base, LineToBase, PointStyle doesnt work properly
please, could You give a hint or answer....
Im using classical CheckBox for controlling following code:
void CCallThemView::OnBnClickedCheck15()
    if(m_RunEcgCtrl.GetCheck()==1)
        m_ECGgraph.Plots.Item("Plot-1").FillToBase = TRUE;
        m_PMpulseGraph.Plots.Item("Plot-1").FillToBase = TRUE;
        m_RpulseGraph.Plots.Item("Plot-1").FillToBase = TRUE;
        m_ECGgraph.Plots.Item("Plot-1").FillColor = RGB(0, 0, 128);
        m_PMpulseGraph.Plots.Item("Plot-1").FillColor = RGB(0, 0, 128);
        m_RpulseGraph.Plots.Item("Plot-1").FillColor = RGB(0, 0, 128);
    else
        m_ECGgraph.Plots.Item("Plot-1").FillToBase = FALSE;
        m_PMpulseGraph.Plots.Item("Plot-1").FillToBase = FALSE;
        m_RpulseGraph.Plots.Item("Plot-1").FillToBase = FALSE;
My problem is that the program is sometime frozen. It issue from this function. I'm sure.  How can I secure and hold the program to work properly? Where is the problem?
I'll be glad for any help...
Thank you.
Emta
(4,256 Views)
Hi Emta,
There is a known issue with some of the older versions of the .ocx when using the FillToBase property.
I've attached a hot fix that has taken care of the problem in the past. Give this a try and let us know if you are still having problems.
Thanks Emta, have a good one!
Dan Weiland - Applications Engineer - National Instruments
Dan Weiland
(4,237 Views)
Im so sorry. It doesn work.
Error message cwui:
Error loading control.  A newer version needed. The default settings for the control will be used.
I cant kill this message window. I cant continue with this version.
Im using Measurement Studio version 7.1.0.306 with MSDE 7.1.3088
MS. net framework 1.1.4322
Thanks for advice.
Emta
(4,225 Views)
Hi Emta,
    This error usually pops up when moving an application from one computer to another, but the two computers have different versions of Measurement Studio installed. Basically the original version of the control and the version currently installed on the computer do not match.
Has this been the case in the past? Or is the only update to the controls you've installed the hotfix that was attached to the last forum post?
Also is this an error that's coming up during deployment, or are we still in the development stage?
Thanks Emta
Dan Weiland
(4,211 Views)
Hi Emta,
    Try downloading the following Measurement Studio updater and running that. It should take care of the problem.
http://digital.ni.com/softlib.nsf/websearch/2AAC97491D073A6C86256EEF005374CE?opendocument&node=132060_US
Dan Weiland
(4,203 Views)
