Measurement Studio for VC++
Find timestamp array delta
Hi,  I need to determine a change in timestamps programmatically.  See attached.  Time elapsed between array elements is roughly 8 seconds.  How could I find this delta?
(6,595 Views)
I have included a code snippet in this - an updated attachment.
(6,581 Views)
An easy approach to getting the difference in time between time stamps in genreal would be to use the Get Date/Time in Seconds function as well as some of ther other functions in the timing pallete. You would need to use the function twice and subtract the value of one from another.  This calculates the elapsed time.
I think you could apply this same concept to your code by creating another loop (or maybe even the same one) with a shift register that stores the previous time stamp.  Subtract the timestamps and it should produce the elapsed time.
I dont't know if this helps or not.
Cameron T
(6,559 Views)
Accepted by topic author Newton2this1
Cameron,
Thank you for the reply.  I actually figured it out using 'Delete from array' twice from within a For Loop.  See the updated snippet.  The relative time was determined for a 3D plotting application.  I figured 15 minutes elapsed in 1904 (LabVIEW default) is the same as 15 minutes elapsed today and I found a difference between timestamp1 and timestamp2!  🙂 John
(6,554 Views)
