Measurement Studio for VC++
Finite sampling on each trigger
Hello? I have some error problem regarding to DAQmxSetReadOffset().
Whenever I set this codes,
short* DataBuffer = new short[_countof(dbuffer)]; ... DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",fRate,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,_countof(dbuffer) )); ...
 I receive this error:
_countof(dbuffer) is a buffer size of data. I wish to acquire _countof(dbuffer) size sample.
I have tried this, but no use.
DAQmxErrChk (DAQmxGetReadAvailSampPerChan(taskHandle,&reading)); if(reading>_countof(dbuffer)) { DAQmxErrChk(DAQmxSetReadRelativeTo(taskHandle, DAQmx_Val_MostRecentSamp )); DAQmxErrChk(DAQmxSetReadOffset(taskHandle, -(_countof(dbuffer)) )); }
I'm converting DAQ to DAQmx..from Parkoz.com
(6,459 Views)
Accepted by topic author anarkie
Ah,,,I have solved the problem. It was using while() condition, but it is causing that error.
The continuous sampling needs while() but in this case it doesn't need it.
(6,457 Views)
