Measurement Studio for VC++
Get externalCalibrationLastTime
I use "nisyscfg.h" library,
I can't get the property data "NISysCfgResourcePropertyExternalCalibrationLastTime", the return struct data are all "0",
but i can get the property data "NISysCfgResourcePropertyInternalCalibrationLastTime", the return data have value. why ?
is the library version issue ?
Thanks.
(349 Views)
It could indeed be a version-related issue or a hardware-specific limitation where external calibration data isn't supported or recorded by your device. You might also want to verify if the hardware in question has ever undergone external calibration. For related tech data lookup, you can explore Oregon arrest finder tools which demonstrate similar structured data retrieval systems—might give you some ideas for error handling or validation approaches.
(286 Views)
