Measurement Studio for VC++
HOW to make NI6537 work in 2.5V voltage level
HI ALL,
I just check on datasheet of NI6537, it shows this card work in 2.5V 3.3V kinds of voltage levels for digitial output.
But the default setup is 3.3V. So how can we set it to 2.5V (in digital output)  (using C++).
I once got one function:
int32 DAQmxSetDigitalLogicFamilyPowerUpState (const char deviceName[], int32 logicFamily);
Sets the digital logic family to use when the device powers up.
But it seems not work in my codes. Does anyone know how to set it up ?
Liang
Message 1 of 8
(7,535 Views)
Hi Liang,
Please, refer to the following document on information how to setup DAQmxSetDigitalLogicFamilyPowerUpState:
NI-DAQmx C Reference Help: DAQmxSetDigitalLogicFamilyPowerUpState
Mikhail
RF Toolkits, Product Support Engineer
Message 2 of 8
(7,528 Views)
Hi Mikhail,
Thanks for your answer. But I once try this function in my code (at the beginning), it seems not work, because the function return a negtive value.
Even in the Measurement Studio, i set the powerup state to 2.5V, the output still shows 3.3V in the test panel.
It confused me too much and cost too much time.
Thanks anyway.
Liang
Message 3 of 8
(7,523 Views)
Hi Liang,
I tested a simple code with DAQmxSetDigitalLogicFamilyPowerUpState function and I did not run into any errors.
Refer to the attachment. The code simply writes 1s to port 0 and sets the Power Up state to 2.5V. Dev27 is my NI 6537 device.
Here is the software I have installed on my machine: Windows 7 (32-bit), Visual Studio 2010, NI DAQmx 9.6
Hope this helps!
Mikhail
Message 4 of 8
(7,519 Views)
Accepted by topic author leo517
Hi Liang,
Also, if you want to change digital logic level of your output from 3.3V to 2.5V have a look at the following example: Static Digital Output with Adjustable Logic Level
Mikhail
Message 5 of 8
(7,503 Views)
HI Mikhail ,
This one solved my problem,  But I don't know why (DAQmxSetDigitalLogicFamilyPowerUpState) doesn't work in my project.
Appreciate your help.
I spent almost half month on this small question.
Thank you
Liang
Message 6 of 8
(7,497 Views)
Hi Liang,
Power Up State only works for the logic level of your board when you reset or power up the system.  Once you generate any data after that point, it will revert to its default logic level of 3.3V.  The example above adjusts the correct property.  We apologize for the inconvenience and I hope you have much success with your application!
Kyle A.
Senior Applications Engineer
Message 7 of 8
(7,492 Views)
Hi Liang,
Kyle A.
Message 8 of 8
(7,492 Views)
