Measurement Studio for VC++
Help with problems when calling C++ DLLs
Using ts to call the C++ module DLL written by vs. The parameters of the function have not been displayed. Is my interface written in C++ wrong? Sincerely ask for helpThis is my module editing interface, there is no function variable a, bThis is my module editing interface, there is no function variable a, bThis is my CppThis is my CppThis is my header fileThis is my header fileThis is my module editing interface, there is no function variable a, bThis is my module editing interface, there is no function variable a, b
(2,739 Views)
you can new a lib project ,project have a .def file, you can write dll extern name in that file . like this:
; EncryptionLibrary.def : 声明 DLL 的模块参数。
LIBRARY
EXPORTS
; 此处可以是显式导出
des_encrypt @1
des_decrypt @2
Base64ToNomalCode @3
NomalCodeToBase64 @4
des_encrypt_char @5
des_decrypt_char @6
Base64ToNomalCode_char @7
NomalCodeToBase64_char @8
generateRSAKey @9
rsa_pub_encrypt @10
rsa_pri_decrypt @11
rsa_pri_decryptFile @12
Base64ToNomalCode_cplus @13
Createsharememory @14
Readsharememory @15
Writesharememory @16
rsa_pub_encrypt_cplus @17
rsa_pri_decrypt_cplus @18
rsa_pri_decryptFile_cplus @19
(2,598 Views)
