Measurement Studio for VC++
How can I call NI-DAQmx with Borland Builder C++
how can I call NI-DAQmx functions with Borland Builder C++?
Thank
Fabrizio
(5,769 Views)
You should use the ANSI C API to call NI-DAQmx with Borland Builder C++. For more information, see the DAQ Quick Start Guide, the NI-DAQmx Help, and the NI-DAQmx C Reference Help under Start>>Programs>>National Instruments>>NI-DAQ.
(5,754 Views)
I have the same problem as Fabrizio !
I can run properly the DAQmx ANSI C functions with VC++ but I can't use them with Borland because of a compliance problem.
So I tryed to use the Coff2omf software to create a correct ".lib" file ...
But it still doesn't work ...
Julien
(5,623 Views)
If the tools that Borland provides for converting import libraries don't work for the the DAQmx import libraries, I think your only option will be to link explicitly to the DLL through LoadLibrary and GetProcAddress.
(5,617 Views)
You can get the Borland import library for DAQmx from here.
Hope this helps
Bilal Durrani
NI
(5,597 Views)
Thank's Bilal !!!
It works !!
Julien
(5,591 Views)
