Measurement Studio for VC++
How can I change Frame.Knob size?
I have CNiKnob control on my dialog.
Style of this knob is like a speedometer.
There are small sub-knob in center of this control(Pointers begins from it). It named Frame.Knob in Images tab of Properties. I need to set a custom size to this sub-knob, that is independent from total size of the whole Knob control!
How can I do it ?
(3,882 Views)
Hi ASW,
I do see what you are referring to in terms of the Frame.Knob text in the Images tab. However, my initial thought is that you will not be able to edit this feature directly. Thus, I will need to talk with R&D about this to get their take on the issue.
Best Regards,
Jonathan N.
(3,858 Views)
Thank you for your answer!
Who is a R&D ?
If I cann't do this directly, may be there are any indirectly way 🙂 ?
Can I get source code of CNiKnob class (from NI ), recompile it, and use my own ActiveX control?
(3,857 Views)
Hi ASW,
I just talked with the Measurement Studio R&D (Research and Development) department and they mentioned that this property was unable to be edited.
As far as getting our source code for that class, I am sorry but we can't hand that out.
Best Regards,
Jonathan N.
(3,848 Views)
