Measurement Studio for VC++
How can I create an array of CNiButtons in VC++ ? I get an exception occasionally when I try to use Create method.
How can I create an array of CNiButtons in VC++ ? I get an exception occasionally when I try to use Create method for every single member of an array. It's dynamically allocated array. I'm trying to put those buttons on the dialog.
(2,941 Views)
Can you please post code that demonstrates how you're calling Create to dynamically create the control? Thanks.
- Elton
(2,941 Views)
