Measurement Studio for VC++
How can I do the CNiReal64Vector as a global variable?
My problem is with the CNiReal64Vector. Ive tried to define this vector as a global variable in the header file:
public
NI::CNiReal64Vector plotData(50);
but the debuger flushed error : Syntax error ´constant´.
Of course,  I used usually square brackets:
 public:
double plotData[50];
Is it possible define the array of CNiReal64Vector as a global variable?
Thank You.
Best Regards
Emta
(3,591 Views)
In the header (.h) file, declare the variable like this:
extern NI::CNiReal64Vector plotData;
In a source (.cpp) file, define the variable like this:
This will cause the compiler to generate a single instance of the plotData global variable and a call to the CNiReal64Vector constructor that takes an integer that specifies the initial size. I believe that this is what you are trying to do.
(3,588 Views)
Thank You very much. Im working with Measurement Studio for a short time. emta
(3,585 Views)
