Measurement Studio for VC++
How can I programmatically determine the capabilities of a card under NI-DAQmx (e.g. max sample rate, number of AI/AO/CTR channels, etc.
Ok now I downloaded and started to use the NI-DAQmx driver (not the base), and indeed I get a lot of properties.
But I'm still not able to find the capabilities of the boards installed. Fx:
I found two methods: DAQmxGetAIRngHigh and DAQmxGetAIRngLow, they seems to read the valid input range of the board, despite the setting specified in the DAQmxCreateAIVoltageChan method; that's fine. I don't understand why they require a task handle however, and why they must be called after creating a channel, I would expect a device name?
Then I tried to call the method DAQmxGetAISampAndHoldEnable. This created and error; I guess that this means that sample-and-hold is not supported on the board I have, that's true.
But how do I find:
· the maximum sample rate of the board?
· the possible valid terminal configurations of the board RTSE, Diff, or NRSE
· support for analog or digital input trigger
· etc.???
Please help.
-cpede
Message 11 of 17
(2,647 Views)
I've had the same problem. The info is not exactly forthcoming in the user's manual. 😛
I found the most effective way to find out about the board's capabilities was to explore the board using Max and play around at the test screen.
Good luck.
Jim
Message 12 of 17
(2,642 Views)
Cpede,
All that info can be found in the spec sheet for the board.
M Series here.
E Series here.
Programmatically, for max sample rate, you can use this function: DAQmxGetSampClkMaxRate(TaskHandle taskHandle, float64 *data);
For valid terminal configurations, I'm not aware of any E or M series device that is not capable of RSE, NRSE, or Diff.
As for support for analog or digital trigger, again, I'm not sure if there are any E or M series devices that are not capable of this.
-Alan A.
Message 13 of 17
(2,623 Views)
Thanks for the reply.
I'm using NI-DAQmx v7.3 and I don't have a method called DAQmxGetSampClkMaxRate?
I have a method called DAQmxGetAIConvRate, but this changes value dependent on the number of channels created.
Fx. I have an old PCI-MIO-16E-1 board, with 1 channel created it returns 1.25 MS/s as specified for the board. If I create 2 or more channels it always returns 1 MS/s. Then again this would be ok if the sample clock returned could be used in the DAQmxCfgSampClkTiming method. But for 1 channel I can use 1.25 MS/s, but for multiple channels I cannot use the 1 MS/s returned, but have to do the old trick dividing with the number of channels: 1.25 MS/s / [number of channels ] ???
My point is that it should be possible to read these properties from the driver. Otherwise you are not able to make a dynamic system, but a system of devices you know in advance!
You are probably right with respect to the RES, NRES and Diff. But how do I then detect if the bard support unipolar input? I know that one of my boards PCI-6023E, does not support this, how do I detect that and how do I specify the polarity?
-cpede
Message 14 of 17
(2,622 Views)
cpede:
Thanks for your feedback, cpede. We will be taking your requests into consideration in planning for future versions of NI-DAQ.
Chris W.
.NET and C++ DAQmx Team
NI R&D
Message 15 of 17
(2,567 Views)
Any progress here yet? I assume the functionality is there and is used by MAX, it is only undocumented?
What about DAQmxGetSystemInfoAttribute and DAQmxGetDeviceAttribute that I found in NIDAQmx.h. Where is description of  'int32 attribute'  parameter?  Both functions are missing in "NI-DAQmx C Reference"?
Message 16 of 17
(2,417 Views)
Hi vldmr-
Yes!  With NI-DAQmx 8.0 a list of new properties are available through the driver API.  These include the ability to list all available I/O channels.  Discussions of these new properties are available in the NI-DAQmx C Reference Help under NI-DAQmx>>C Properties>>List of Device Properties.
Hopefully this helps-
Tom W
Message 17 of 17
(2,388 Views)
