Measurement Studio for VC++
How can I use CWGraph3D for Visual C++,How the Variant operate?
I have a VC++ project that use CWGraph3D to show data.
How I use it's method Plot3DCurve(VARIANT& xVector,...)
what's the VARIANT type.
How do I use the VARIANT type to do this job?
(3,894 Views)
If you have Measurement Studio, you really should be using our native Visual C++ tools instead of the ActiveX controls directly. It will save you A LOT of time trying to deal with VB/ActiveX data types.
In case you don't have Measurement Studio for Visual C++ and just have the 3DGraph ActiveX control, not the MFC classes, then I attached a ZIP file with several examples of using the 3Dgraph ActiveX control in Visual C++.
Best Regards,
Chris Matthews
(3,894 Views)
Is there anyway that you can use the 3Dgraph that comes with Measurement Studio for VC++? It has the same functionality and the added benefit that you won't have to deal with Variants. Since you are in VC++, you can find the 3Dgraph control in the Visual C++ Controls palette. If you don't have it there, run the Measurement Studo Add/Remove Components Wizard to add it to your project.
With the native VC++ 3Dgraph, your Plot3DCurve will have the following prototype:
void Plot3DCurve(
const CNiVector& x,
const CNiVector& y,
const CNiVector& z);
Let me know if you have further questions.
Azucena
NI
(3,894 Views)
Thank you for response this question so soon.
Because I do not have Measurement Studio for VC++,
I do not have CNiVector data type.
Now I have CCWSafeArray from Chris Matthews,
National Instruments.
I could use it's contructor and AccessData() method
to create an array like this:
double xArray[3]={0,1,2};
double yArray[3]={0,1,2};
double zArray[3]={7,8,9};
double wArray[3]={0,0,0};
CCWSafeArray xSafeArray(xArray,3);
CCWSafeArray ySafeArray(yArray,3);
CCWSafeArray zSafeArray(zArray,3);
CCWSafeArray wSafeArray(wArray,3);
m_Graph.Plot3DCurve(xSafeArray,ySafeArray,zSafeArray,wSafeArray);
It works very well.
But now I would like to use Plot3DSurface() method.
I write C++ code like this:
dou
ble zMatrix[3][3]={{1,2,3},{4,5,6}.{7,8,9}};
double wMatrix[3][3]={0};
CCWSafeArray zSafeArray2D(zArray,3,3);//error line
CCWSafeArray wSafeArray2D(wArray,3,3);//error line
m_Graph.Plot3DSurface(xSafeArray,ySafeArray,zSafeArray2D,wSafeArray2D);
It could not work.Complier tell me:
error C2664: '__thiscall CCWSafeArray::CCWSafeArray(unsigned short,long,long,long)' : cannot convert parameter 1 from 'double [3][3]' to 'unsigned short'
I don't know what's wrong.
(3,894 Views)
