Measurement Studio for VC++
How can i make the tank go to 250??
the problem i have is the following: the tank goes to 270 when it fills from Ingr 1 , the tank should fill in to 250  and by 15 each time until it gets to 3000 and it should decrement to 1000 from 3000, i hope some can help me.
David
(5,234 Views)
You should be attempting to modify the Scale and Data Entry Limits properties of the control. When I opened your file I saw the scale was 0-6000. Try adjusting that. The try adjusting the Data Entry Limits properties nodes for max, min and increment. I'm not positive this is what you were looking for, but just let us know if it isn't!
(5,208 Views)
