Measurement Studio for VC++
How do I resize the graph frame, plot area, etc. on a CWGraph control?
I'm doing an XY-scatter plot, and points along the X and Y axes hang over the edge of the plot area, sometimes covering up the value labels (we use rather large point sizes). Is there a way to resize the graph frame, plot area, or axis areas so that I can avoid this problem?
(3,192 Views)
In your case, it would be better to increase the size of the whole graph. It is not very simple to do so in VC++, but there is an example program that shows how to accomplish that:
http://zone.ni.com/devzone/devzoneweb.nsf/opendoc?openagent&0138AA28F42632168625698C0053AB1E&cat=43702593E95C5CAD8625688D005DA06F
Mika Fukuchi
Application Engineer
(3,192 Views)
Thanks for your help. However, I'm actually programming in C#, so the example doesn't translate very well. I ended up just manually setting the Axes Min and Max with a buffer on the edges.
Natalie
(3,192 Views)
