Measurement Studio for VC++
How do I turn on the property Intf.LIN.Term?
I recently started using the USB-8506.
I can't find such variables or structures.
Komao
(13,213 Views)
Hi komao
Check out the XNET Manual below. I believe you'll be interested in the following pages:
nxSetProperty: pg. 5-119
Interface:LIN:Termination: pg. 5-332
NI-XNET Hardware and Software Manual - National Instruments
http://www.ni.com/pdf/manuals/372840h.pdf
Jiwhan S.
Technical Support Engineer
(13,157 Views)
Hi Jiwhan
NxPropSession_IntfLINTerm that you taught me was a hint.
I found the nxSetProperty () and nxGetPropertySize () APIs.
I made the following function.
|void setNxProperty(nxSessionRef_t sessionHandle, u32 propertyID, void* propertyValue) {
| nxStatus_t nxStatus = 0;
| //Queries the property size
| u32 propertySize = 0;
| nxStatus = nxGetPropertySize(sessionHandle, propertyID, &propertySize);
| if (nxStatus != nxSuccess) {
| DisplayErrorAndExit(nxStatus, "nxGetPropertySize");
| //Set properties with that size
| nxStatus = nxSetProperty(sessionHandle, propertyID, propertySize, propertyValue);
| DisplayErrorAndExit(nxStatus, "nxSetProperty");
And I called it as below.
| u32 intfLINTerm = nxLINTerm_On;
| setNxProperty(nxSessionHandle, nxPropSession_IntfLINTerm, &intfLINTerm);
I think the data line will be pulled up if the settings are fine.
So I checked the voltage between pins 3-7 of D-SUB, but it was 0V.
Perhaps the setting has failed.
Compilation passes and there is no error display.
Is my verification method bad?
Although the explanation was delayed,
the development environment is VS2017.
Komao
(13,150 Views)
