Hai to all, By using one COMServer(VC++), that COMServer exchange the data between TestDirector and LAbVIEW7.0, How to call LabVIEW function in activex, is it posible or not? if posible please post your answer.
You can call the LabVIEW ActiveX Automation Server. This can be done from any programming language. Following the links below, you will find some examples.
Calling LabVIEW from C++ Using ActiveX http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3E21356A4E034080020E74861&p_node=DZ52051&p_submitted=N&p_rank=&p_answer=&p_source=External
Calling LabVIEW as an ActiveX Server from Visual Basic http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3E3D756A4E034080020E74861&p_node=DZ52051&p_submitted=N&p_rank=&p_answer=&p_source=External
Communicating with LabVIEW from Delphi using ActiveX http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3E8D156A4E034080020E74861&p_node=DZ52051& p_submitted=N&p_rank=&p_answer=&p_source=External
Calling a LabVIEW VI with the LabVIEW ActiveX Automation Server http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3D85956A4E034080020E74861&p_node=DZ52156&p_submitted=N&p_rank=&p_answer=&p_source=External
Remote Control (Launch) of LabVIEW Using ActiveX/DCOM http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B123AE0CBA64111EE034080020E74861&p_node=DZ52051&p_submitted=N&p_rank=&p_answer=&p_source=External
