Measurement Studio for VC++
How to Set input mode RSE DIFF NRSE
How can I program the input mode(RSE, NRSE, DIFF) use CCWAI class in Measurement studio? I am using PCI-MIO-16E-4 DAQ board.
(3,555 Views)
Hello
you can do that using MAX and changing the properties of the device or if you need to do it programmatically, you can try the following:
Access the CWAIChannel object from the CWAI object. And once to get the handle on that, you can call the setinputmode method
CWAIChannel singleChannel=m_ai.GetChannels().Item(_variant_t(1.0));
//_variant_t is a helper class from comdef.h
//Set to NRSE
singleChannel.SetInputMode(3);
You can set the following values for the various modes
cwaiDefaultInputMode=0
cwaiDIFF=1
cwaiRSE=2
cwaiNRSE=3
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,555 Views)
Thank you,
When I tried to use singleChannel.SetInputMode(3), the program calls CATCH_ALL(e){} of oledisp1.cpp, so I couldn't use set function of C_CWAICannel, but all get funtion is works. does anybody know why?
My program like this:
C_CWAIChannel singleChannel = m_ai.GetChannels().Add(channelString, CNiVariant(upper), CNiVariant(lower), vOptional, vOptional);
singleChannel.SetInputMode(2);
singleChannel.SetGain(10.0f);
singleChannel.SetScaleOffset(0.0f);
And who can tell me the relationship of gain, offset, scale and input range for PCI-MIO-16E-4 board?
(3,555 Views)
