Measurement Studio for VC++
How to achieve the multiplots to show the temperature from channels?
I manage to get the CJtemp already, but I can only show one channel of temperature. Sad. I try a lot of methods, and investigated into the prob. Found that the arrays to stored the readings are not correct. Pls hav a look at my code, I dunno how to handle it in visual c++, through i hav the vb example.
Thanks a lot.
(2,964 Views)
Hello
To use multiple plots on a chartm I would recommend seting up your data as CNiVector and CNimatrix objects. You can find examples for Visual C++ as well, if you check out ..\Measurement Studio\VC\Examples\Ui\Graph\Graph Example folder, this demonstrates how to do multiple plots on a graph.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(2,964 Views)
