Measurement Studio for VC++
How to chang Plot's Y values
I have shown five curves in a graph, because their Y values are close to each  other, it is difficult for me to read the time difference between every two curves. So I want to change a curve's Y values, I want to know if the graph has the function that it can add a Y offset to a certain curve, not using code to change the Y values.
(6,340 Views)
Hi Victor!
The answer to this question is different depending on whether you are using the .NET controls or the ActiveX controls, but I think that the following forum posts should answer your question for either case.  Let me know if you need further information!
http://forums.ni.com/ni/board/message?board.id=230&message.id=2459&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=232&message.id=5067&requireLogin=False
NickB
Applications Engineering
(6,310 Views)
