Measurement Studio for VC++
How to change the access properties of a USB Device
I  am trying to Implement one function that is like
ChangePartitionAccess(DriveLetter) - switch USB partition to read-only or read-write
i am passing the drive letter of the usb device partition to this method
and it should change the access of the device partition to read only if it is in read - wirte mode
and it should change the access to read - write mode if it is in read only mode.
i would like to know which api i have to use to achieve this functionality
i am using visual studio 2005.
Thanks in Advance.
Message 1 of 1
(6,270 Views)
