Measurement Studio for VC++
How to configure absolute shutter parameter with ni-imaq 1394 in C++ environment
When i call the command: imaq1394SetAttribute(sid, IMG1394_ATTR_ABSOLUTE_SHUTTER, 0.001) the driver send me the following result : Invalide pointer. The pointer may be NULL when it should be non-NULL, or non-NULL when it should be NULL. How can i set the shutter in absolute mode without any bad pointer result ?? Help me, please.
(3,861 Views)
Hi
What is the pointer expected in this function? sid is an array? Check if you pass in the function the correct type of data ...
Kamal
NIF
(3,821 Views)
