Measurement Studio for VC++
How to configure multiple AI channels scanning at differerent rates in Visual C++
is it possible to scan multiple AI channels (e.g. 😎 at different sampling rates each of them?
If yes, I am intersted in knowing the DAQmx C++ function that should be used to configure the rates this way.
I am using NI USB 6000-6001-6002 series cards.
Thanks.
(3,231 Views)
Hi cnardo,
unfortunately is not possible, especially on those low cost devices.
I suggest to run all the AI at the max rate you need and take only the useful samples.
(3,189 Views)
OK. Thank you.
(3,161 Views)
