Measurement Studio for VC++
How to display a char* array with NI graph control?
My developing environment is VC2005sp1 + MeasurementStudio8.1.1.
It seems that PlotY could only accept CNIVector type as input data source and PlotY could not accecpt char* array or unsigned int array as input data source. Is it true?
My data is stored in a large char* array. Each character(or Byte) of this array represents a value point. The size of this char* is of LARGE_INTEGER type. How could I display every Bytes of this char* array with NI graph control?
My code looks like this:
     CNiReal32Vector        mNIVectorforDisplay;        // NI vector for display.
//   pYDisplay is the points of char* array.  liSizeofField is the size of this array, which is of LARGE_INTEGER type
     mNIVectorforDisplay    =    CNiReal32Vector(liSizeofField.QuadPart, (char*)pYDisplay);
//   The above two line can work through, while the following trigers an error.
     pWaveGraph->GetPlots().Item("Y").PlotY(mNIVectorforDisplay);
Would you plz tell me how to realize this scenario?
I’m looking forward to your response and kindly help.
Thank you.
(6,896 Views)
I need your help...
(6,887 Views)
Hi
I am not very familiar with Measurement Studio, so correct me if I am wrong.
It seems that you mistakenly take method PlotY as function PlotY. From the help doc of Measurement Studio, you could see the differences.
(6,883 Views)
I partially solve this problem now. I use "for" loop and "=" operator to fufill the task, which is quiet slow and looks ugly.
The code looks like this:
    for (int i=0; i<1000; i++)
        mNIVectorforDisplay[i] = *(LPBYTE)((unsigned char*)((pYData)+i));
    m_Wave.Plots.Item("Y").PlotY(mNIVectorforDisplay);
My question is : Could NI Graph control support native C++ arrays and pointers, not wrapped CNIVector** class.
I go through some of the code behind, I found that inside the CNIVector** class constructor, low efficient "for" loop and "=" operator are used to convert a C++ array to
wrapped CNIVector** class. This manner could not be attractive in the need for speed and efficiency.
Who can tell me how to solve this problem?
(6,834 Views)
The graph can take in a char* and plot it to the graph directly without having to use a for loop.
Here is partial code that uses a char array and sends it to a waveform graph. You might want to try something similar to this:
char* data;
double value;
long size = 10;
long x = 0;
data = new char[size];
for(x = 0; x < size; x++)
   const double maxValue = 10.0;
   value = (double)rand() / RAND_MAX * maxValue;
   data[x] = (char)floor(value);
m_Graph.PlotY(CNiUInt8Vector(size, data));
delete[] data;
Hope this helps!
Chris T.
(6,799 Views)
