Measurement Studio for VC++
How to dynamically adjust Frequency, Phase and Amplitude for a Generated Sine Wave in C/C++?
I wonder if anybody know how to dynamically adjust Frequency, Phase and Amplitude for a Generated Sine Wave in C/C++? This is a part of my project: I need to dynamically generate a sine wave voltage signal by some calculation using the data from a simultaneous analog input and another signal.
Your help will be appreciated so much!
Marlon
(3,873 Views)
Hello marlon,
What DAQ board are you using?
This would greatly help me answer your question.
Nicholas C
Applications Engineering
(3,873 Views)
Hi, Nick:
Sorry, I use PCI-6110.
Thank you.
(3,873 Views)
Hello Marlon,
Here is an example of changing frequency and ampliude for an E-series device in Labwindows/CVI. The programming should be similar in C for your S-Series device. As is says on the linked webpage above, this process is going to be very processor intensive since you will continually be creating a buffer.
Nicholas C
(3,873 Views)
