Measurement Studio for VC++
How to generate a value to a slide randomly and continuously using measurement visual c++?
i would like to generate a signal to a slide randomly and continuosly when start and stop function is pressed. How to do this part of coding and what type of datatype in this software should be used?
(3,007 Views)
You can use a timer and generate a random value and set it to the slide in the WM_TIMER message handler. I think the Control Metrics example that ships with Measurement Studio for Visual C++ behaves similar to what you describe and that's what it does. Check it out under the Examples\UI\Common\Control Metrics subdirectory of your Measurement Studio for Visual C++ installation directory.
- Elton
(3,007 Views)
