Measurement Studio for VC++
How to hide certain points on a CNiGraph plot
Hi there,
I use a CNiGraph to plot (function PlotXY()) data which is stored in a CNiReal64Matrix array.
It works fine but sometimes, some of the points in the array are invalid points and I would like no to plot them, ie. hide them, which would then interrupt the plotted line in some areas.
Anyone knows how to achieve this?
Bob
(8,556 Views)
Hello Bob,
Have you considered creating a simple function that accepts your array as an input, iterates through it, and copies only valid data points over to a new array to be returned in its place?  I think this may be a fairly easy approach to employ in order to achieve your end goal.
(8,531 Views)
Accepted by topic author Bob666
Bob,
I believe I may have neglected your desire to plot discontinuous line segments.  If this is indeed your end goal, this resource may be of help to you.
(8,527 Views)
Thanks a bunch Matt,
This is exactly what I was after.
Bob
(8,513 Views)
