Measurement Studio for VC++
How to pass a openCV Mat from C/C++ DLL to Labview
Full Question:
          What is the best way to handle a openCV Mat given in a C/C++ DLL to use the data in Labview?
Problem:
        A C/C++ DLL is given where i have a global Mat which contains data. Now i wanna use this data in LabView.
       What is the best and most efficient way  to pass a openCV Mat to LabView?
       I tried it by passing an in/out pointer parameter, where i tried to pass the Mat data starting adress, but it didn´t work.
(6,197 Views)
Hi
Did you already have a look at the following post? Have a look at  the solution in green.
http://forums.ni.com/t5/Machine-Vision/How-can-I-get-an-image-back-to-labview-from-opencv-dll-code/m...
Did this help?
Best,
Ale
(6,140 Views)
