Measurement Studio for VC++
How to read TDMS file use DDC_GetDat​aValuesStr​ing in C language.
1. Below code is correct, because the numDataValues is one, machine=sibot
char ss[10]={0};
    char *strMachine=new char[1];
    *strMachine=ss[10];
    nullChk (strMachine = (char *) malloc (sizeof (char) * (unsigned int)numDataValues));
    ddcChk (DDC_GetDataValuesString (channels[i], 0, (unsigned int)numDataValues, &strMachine));
    printf ("Channel value for Machine : %s\n", strMachine);
---then show "nel value for Machine : sibot"
2. But when the numDataValues is more one, I can't get all the data in the TDMS file, only can get the first one.
eg:
data one is FI,
data two is O
but I only can get FI....
what's wrong?? How to solve it?? The data format as attachment.
(5,735 Views)
Hi KittyDeng,
I guess the problem is from here:
You allocated a char array of only 1 element which will not hold as many chars.
The best way to solve the problem is to allocate more memory than that of the data, where in your case, you can write:
char *strMachine=new char[20];//or set more than 20
Hope this helps.
Zhiqiang Tu
NISH AE
(5,711 Views)
Actually, when get the array data, I have modified the code:
ddcChk (DDC_GetNumDataValues (channels[i], &numDataValues));  //获取数据长度
char ss[5]={0};
  char *strCode=new char[numDataValues];
  *strCode=ss[5];
   ddcChk (DDC_GetDataValuesString (channels[i], 0, 7, &strCode));
  printf ("Channel length for strCode : %s\n", strCode);
(5,709 Views)
