Measurement Studio for VC++
How to receive USB device handle from DLL
Hi All,
I'm working on a firmware running on a development kit and I'm trying to communicate with the board through USB from Labview in Windows environment. For that, I've built a DLL which enumerates, opens Read/Write file handle and does a few other functions. I'm using standard Windows APIs for USB initialization.
I use  "Call libr. function node" in labview to call these dll's. Inside the DLL, I use a function to initialize the USB which returns a device handle to the labview. My question is,  in "Call libr. function node" what is the parameter type I should use to receive the device handle? The device/file handle is defined in the WinAPI as a void pointer.
Any help will be much appreciated.
Hari
(8,713 Views)
Hello Hari,
Have you seen this thread?  DLL call with HANDLE type
(8,692 Views)
Hi Charlie,
That thread is really helpful. Thank you.
Hari
(8,690 Views)
how to receive and send bulk data from microcntroller using usb communication and dll concept ...same dll i will use in application1 and application2 for sending and receiving data
(3,855 Views)
Hey I would recommend starting a new thread on our discussion forum with details about your specific issue. This thread is 9 years old so any new posts on it will not get much visibility.
Applications Engineering
(3,846 Views)
