Measurement Studio for VC++
How to save data acquired from NI-DAQ in text format instead of TDMS using the DAQ-mx ANSI C code?
I wanted to save data acquired from NI-DAQ (for example, NI 9234) in a file using the DAQ-mx ANSI C Code. The response I got was as follows:-
One way to do it is with TDMS logging. DAQmx comes with functions designed to log to a TDMS file. This is a special file type that is used for collecting data in a logical format. It can be displayed in a TDMS viewer where data is separated into groups and channels. NI-DAQmx provides examples for how to log to TDMS. Look at the TDMS examples in the C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Analog In\Measure Voltage directory.
However, now I want to know is there a way that using that same C code, can we save the data in a .txt file format (Text File) instead of a TDMS file? We actually want to access that file through MATLAB (that's why we want to save it in text format).
Also on an other note, is there a way we can access & open TDMS files by MATLAB?
Sauvik Das Gupta
(6,038 Views)
There's a way you can access TDMS files in MATLAB:
http://zone.ni.com/devzone/cda/tut/p/id/7446
(6,036 Views)
