Measurement Studio for VC++
How to trigger a software interrupt on NI-6527
Hi!
I am using NI-Daq Traditional with NI-6527 DIO board. I would like to know if there is any option for my application to trigger DIO event? To put it simpler, I would like my application to simulate DIO input to DAQ driver. Is there any possibility to do that?
Best regards
(3,926 Views)
Hi kovalenkov,
What are you trying to accomplish by simulating a DIO input to the DAQ driver? NI-6527 supports change occurrence and unstrobed digital I/O. One possibility I can think of is, with the knowledge of the digital state, setting the rise or fall channels in a manner to set a change occurrence. Can what you're trying to accomplish use an event structure in LabVIEW instead?
Lesley Y.
(3,914 Views)
I am not using LabView, but Visual C++. What I am trying to achieve is simulate a driver call of a callback function, so I don't have to set callback function as global and start using mutex whenever I am calling it. It is a really generic problem. Now I didn't notice any function like that in NI-DAQ Traditional documentation. I was hopping you ahd some backdoor functions made.
Message Edited by kovalenkov on 06-15-2005 01:56 PM
(3,901 Views)
Hi kovalenkov,
There's a Config_DAQ_Event_Message function available with NI-DAQ for some events. Unfortunately, the PCI-6527 device doesn't support it.
Lesley
(3,879 Views)
Thank you. I noticed that function. As you said, it doesn't work for 6527. 😞
(3,874 Views)
