Measurement Studio for VC++
How to use CWGraph3D
I want to use CWGraph3D to show a 3D intensity figure., but after i inserted a "Active X control" and added a variable in VC++ 7.0, the compliler always give me an error, "error C2501: 'CCwgraph3d1::CWPlot3D' : missing storage-class or type specifiers". So which library i should include in the code? Is there any sample about how to use the CWGraph3D in VC++? Thank you.
NNQ
(6,738 Views)
Hi NNQ,
If you are using VC++ 7.0 (VC++ .NET), you can find all the User Interface 3D Graph examples located at C:\Program Files\National Instruments\MeasurementStudioVS2003\VCNET\Examples\UI\3DGraph.  There are plenty of examples in there that should get you on your way.
Hope this helps!
Best Regards,
Jonathan N.
(6,727 Views)
how about in visual basic 6?? are there any sample codes??
(5,921 Views)
The samples for VB6 can be found here:
C:\Documents and Settings\All Users\Documents\National Instruments\MStudioVS6\VB\Samples\3DGraph
NickB
(5,899 Views)
