Measurement Studio for VC++
How to use Graph in VC++
Dear Master
Hello?
This is South KOREA. My name is Kim  Sorry I'm poor english.
I have question.
When I use NICWGRAPH in VC++
I can't make Dlg file and Control.
This my first project ... but really difficult for me.
anyway I'll attachment my source file... http://e-newspace.com/source.exe <=== source file.
 Please check it.
I wanna control Graph....
Please....
Thank you.
(3,344 Views)
Hello Kim,
I recommend the Getting Started with Measurement Studio for Visual C++ manual. Chapter 3 of this manual has step by step instructions for creating an application that uses the CWGraph. This manual is a PDF and installs with Measurement Studio in
C:\Program Files\National Instruments\MeasurementStudio\Help
If you cannot find it there, it can be downloaded from here.
Here are a couple helpful hints to get you started:
+ To start a new project that will use Measurement Studio controls, select File»New»Projects, and click NI Measurement Studio AppWizard.
+ When you place a CWGraph on the dialog, you will want to add a member variable for the control so that you can set its properties and call its methods from within your program.
The tutorial in Chapter 3 of the manual describes this in detail.
Also, I did not look at the source you attached. It appears to be a compiled executable.
Eric M
Applications Engineering
(3,327 Views)
