Measurement Studio for VC++
How to use the fct AI_VRead_Scan
Hello I'M trying to use the function AI_VRead_Scan and nothing is being put in my vector. I have a PCI-6034E and I'm trying to read from chanel (1-7)
TKS
GUI
(3,180 Views)
Do you see the signal using Measurement and Automation Explorer? If you do, you can double check that your code has the necessary function calls for doing analog input. In general you would use:
Init_DA_Brds (Board, &BoardCode);
MIO_Config;
AI_Configure;
SCAN_Setup;
AI_VRead_Scan;
You can also try to read the voltages using Scan_OP or Scan_Start.
Good luck with your project!
(3,180 Views)
