Measurement Studio for VC++
I am using a DAQ VC++ example for Waveform generation using analog output. I want to generate a square wave with this analog output. How can I do this?
I am trying to generate a 500mV peak to peak square wave using an analog output from a DAQ6036e board.
(3,079 Views)
Hello
You can check out some of the MSVC examples that are included when you install NI-DAQ on your system.You can find them under C:\Program Files\National Instruments\NI-DAQ. In the AO (Analog Output) folder, you can try some of the double buffered (which are continuous generation ) examples, and use them to start developing your code. For more information on the various functions used, refer to the NI-DAQ function reference manual.
You might want to also go thru the specs for the 6030e user manual to see how fast you will be able to generate the signal, since your particular daq device does not have a FIFO for AO. The output rate will be system dependant.
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,079 Views)
