Hi Jwsinva,
Welcome to the forums! I have a few questions that I would like answered to help troubleshoot your error.
1) Does the OS exception happen inside or outside the console?
2) Can you post back with a screenshot of the exception?
Additionally:
3) When the USB-6210 is connected, and you open Measurement and Automation Explorer (MAX), can you expand the Devices and Interfaces Tab, Expand NI-DAQmx Devices, select the USB-6210, and run a test panel without error?
4) Did you install the DAQmx Driver after the version of Visual Studio you are working with?
5) What version of the DAQmx Driver are you using? This info can be found by expanding the Software tab in MAX and clicking on NI-DAQmx.
Regards, Mallori M.
Mallori M
Sr Group Manager, Education Services
ni.com/training
