Measurement Studio for VC++
I keep having both LabView crashes as well as blue screen crashes. The error in the event log is: The NiRioSvc service terminated with service-specific error 4294967295 (0xFFFFFFFF) Could someone tell me what this error is and how to fix it?
Are you using any RIO hardware in your application?  If not, you can uninstall the NI-RIO driver and this error should disappear.  Otherwise, tell me a little more about your application and when this error occurs.  Thanks!
Brian T
(7,562 Views)
Hi KateH,
You might want to post your Crash Dump, instructions found here: http://support.microsoft.com/kb/307973.  Please post back with more information about your system setup:
What hardware are you using, software versions of LV, RT, FPGA and NI RIO?  Anything else interesting about the system?
Bassett
(7,551 Views)
