Measurement Studio for VC++
I'm looking for the example code of interrupt-driven read.
I've a NI 6509, and I'm looking for the example code of interrupt-driven read.
I am using visual C++ v6.0, Winn 2000.
Thanks.
Inna.
(4,980 Views)
Hi Inna,
Since you are using a 6509, then I assume that you are asking for an example on Change Detection.  When you installed DAQmx, a folder of examples should have also been added to your hard drive.  You can find VC++ 6 examples in the following directory:
C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Digital\Read Values
There is a folder in this directory called:
Read Dig Chan-Change Detection
This should have what you need but please let us know if you are looking for something else or if you have any further questions.
Jeff Tipps
(4,956 Views)
