Measurement Studio for VC++
I need to get the float values returned in the OnProgress or On Acquired events in a CWAI control
I'm using Component Works for developing a generic Acquisition software for multiple devices. I need to know the float or double values returned in the ScaledData variable. The type of ScaledData is TVariant*, and I don't know how to get specific data from it. I also need to know how can I get the different data from different channels in order to have each value in a different Graph. Thanks a lot.
(3,644 Views)
Hi Ignacio,
The Variant returned inside ScaledData is stored as a 2-D array internally when you sample multiple channels, or a 1-D array if you sample a single channel.
If you want to get the array(s) inside it into VC++, I'd suggest you construct a CNiReal64Matrix (2-D) or a CNiReal64Vector (1-D) as follows:
void CContDAQDlg::OnAcquiredDataCwai1(VARIANT FAR* ScaledData, VARIANT FAR* BinaryCodes)
CNiReal64Matrix wave(ScaledData); // constructs a 64-bit floating point 2-D array
m_graph.PlotY(wave); // plot the data in the CWGraph
You can do this because the constructors of CNiReal64Matrix and CNiReal64Vector can take Variants and extract the array(s) from it into a new variable, in this case "wave".
To get the data for individual chann
els, you can extract the 1-D arrays inside it. Keep in mind that the data for channel one is stored in the first column of the 2-D array, the data for channel two is stored in the second column, and so on.
Another tip: To index the CNiReal64Matrix variable "wave", you need to use parentheses. For example to get the element in the first row and first column of the 2-D matrix, you need to write:
float myval = wave(0,0); // indexing wave at row 0, column 0
Hope this helps,
Azucena Perez
(3,644 Views)
Thanks Azucena, your answer was very fast and complete, but I think I should have said I'm working with the free Component Works and I cannot have acces to CNi... classes, only to CW... classes, and they don't work in the same way.
(3,644 Views)
Hi Ignacio,
In that case, it's going to take some real work. I would suggest you look in MSDN for "safearray" and "variant". In C++ the Safearray datatype can hold arrays from VB Variants. It gets more complicated when we have multi-dimensional arrays and we can only blame Microsoft for making VB store 2-D arrays completely different from the way VC++ stores 2-D arrays.
Good luck,
Azucena
(3,644 Views)
