Measurement Studio for VC++
I would like to know how to transform an API C++ application in MFC C++ application to use the measurement studio components or Labwindows CVI
I don t know the way used to transform a C++ with API program in an MFC application using measurement studio or Labwindows CVI.
Thank you for you help.
(3,020 Views)
You can use the Measurement Studio Add/Remove Components Wizard to add Measurement Studio components to your C++ application. For more information, see the "Adding and Removing Components from Measurement Studio Projects Using a Wizard" topic in the Measurement Studio reference. You can find it in the table of contents under:
Visual C++ Help
Tutorials
Measurement Studio for Visual C++ 6.0
If you're using the Measurement Studio update for Visual C++ .NET, this topic will be under:
Visual C++ Help
Tutorials
Measurement Studio for Visual C++ .NET
- Elton
(3,020 Views)
