Measurement Studio for VC++
IIR and FIR on the Fly?
I have question about possibilities of NI Mesurement Studio. Is here the way for using NI Measurement for Online Analysis? I need to make folllowing operation:
FIR and IIR filtering on the fly, thresholding, Peak detection and Pulse description.
Could you give me an example of using Measurement Studio for On the fly filtering and Pulse description? I mean, how to use the components of NI MS for On the fly analysis? I
More thanks for advice or help.
Emta
(3,158 Views)
Hi Emta,
There isn't anything in Measurement Studio explicitly set up for On the Fly filtering - however you can call these analysis functions whenever you want on whatever dataset you have available. So as you bring in your data you can certainly apply whatever filters you would like and get results on-the-fly. It's all dependant on how and when you apply the analysis to your acquired data.
Hope this helps Emta, let me know if you have any more questions.
Dan Weiland
Dan Weiland
(3,149 Views)
