Measurement Studio for VC++
IMAQ I/O & IMAQDX
I'm using NI PCIe-8255R. I linked lamps (ISO outputs 1,2,3) and a IEEE 1394 (firewire) camera to it.
I'm programming in C and using IMAQ-IO API (to switch on lamps), and IMAQDX API (for the camera).
I can use imaqio functions (to switch on lamps) and imaqdx functions (like grab function) separately but I can't do it in the same main program.
For example I can't use : imaqIOOpen() after/before IMAQdxOpenCamera()
Environment :
Windows 7
I installed Labview 2010, NI-IMAQ I/O 2.6.1, IMAQDX 4.1
The error box is this :
In English : "Exception not managed at 0x77979a4c in camera.exe : 0xC0000005 : access violation when reading at 0x000003e6"
Thank you for any help
(5,584 Views)
Hi Powdream,
I think your problem is coming from the fact your are "booking" a resource, here it's the camera. And when a task need to have access to a resource (imaqdx for a grabbing action for example), the resource has to be free. Then you can't make both action at same time. There will be a conflict. The second task (to switch on lamps) will wait that the grab action is finished (that the resource is free).
You have to do it separately.
(5,552 Views)
