Measurement Studio for VC++
Instantiate NI-Controls inside application
I want to instantiate NI Measurement Studio controls (such as CNiButton) inside my application inside a class which shall be comoon for all controls (MFC and NI), thus being derived from CWnd.
Inside this class I am in fact able to instantiate such a control by calling
   CreateControl("{D940E4BE-6079-11CE-88CB-0020AF6845F6}", "*",
       WS_VISIBLE | WS_CHILD | WS_BORDER,
       CRect(10, 10, 50, 30),
       m_pParent,
       7654);
where m_pParent is a dialog window. This will display a CNiButton inside the dialog.
The problem is now that I cannot access any methods of CNiButton.
Attempts like CNiButton *button = dynamic_cast<CNiButton *>(this) fail.
Further attempts with SubclassDlgItem fail, too.
Probably GetControlUnknown() could solve the problem but I do not know how to handle this and don't know which parameters to pass to QueryInterface().
What can I do? Any hint is welcome.
Thank you in advance.
Michael
(6,851 Views)
Some more information about my problem (btw, I build my application using MSDEV 6.0 SP6) I tried this (inside a class which is derived from CWnd): (...) _DCWButton_CI *p = NULL; CreateControl("{D940E4BE-6079-11CE-88CB-0020AF6845F6}", // CLSID for CWButton "*", WS_VISIBLE | WS_CHILD | WS_BORDER, CRect(10, 10, 50, 30), m_pParent, 7654); LPUNKNOWN lu = this->GetControlUnknown(); // this works and gets a reasonable pointer HRESULT result= lu->QueryInterface(IID__DCWButton_CI, (void **)&p); // THIS FAILS! p is always NULL Any idea? What is wrong. Thank you, best regards, Michael
(6,843 Views)
Again, so that everyone can read it:
  m_pParent,
  7654);
Michael
(6,842 Views)
Hi Michael,
here are a few links that you may find helpful. It seems that they are trying to do about the same thing there.
Can I create instances of CWxxx objects?
http://forums.ni.com/ni/board/message?board.id=230&message.id=1886&requireLogin=False
Dynamically Creating/Destroying ComponentWorks Controls in Visual Basic
http://digital.ni.com/public.nsf/websearch/BFF489FE87875A3986256403006F5ECD?OpenDocument
How to create a CW control in Visual Studio .NET at run-time (dynamic creation)
http://sine.ni.com/devzone/cda/epd/p/id/3788
 I hope that this helps.
(6,794 Views)
